[gdal-dev] gdal_translate alters NITF's metadata
Even Rouault
even.rouault at mines-paris.org
Fri Apr 20 17:36:01 EDT 2012
Le vendredi 20 avril 2012 23:28:05, Shawn Gong a écrit :
> Thanks Frank.
> We also find that NITFCreateCopy() doesn't copy the 4 corner GCPs, only the
> geotransform. We'll take a look at your suggestion and report back.
Support for copying GCPs has been added recently in trunk. See
http://trac.osgeo.org/gdal/changeset/23997
> Shawn
> ________________________________________
> From: fwarmerdam at gmail.com [fwarmerdam at gmail.com] On Behalf Of Frank
> Warmerdam [warmerdam at pobox.com] Sent: April 20, 2012 12:35 PM
> To: Shawn Gong
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] gdal_translate alters NITF's metadata
> Shawn,
> I see the values you get for NITF_ISORCE and NITF_IDATIM
> are the default ones in the NITF Create code. Looking through
> the NITFCreateCopy() code in nitfdataset.cpp, it only seems to
> copy a few selective metadata items from the source dataset to be
> creation options when creating the header of the new one. ISORCE
> and IDATIM are not amoung them. I'm not sure why it is so selective.
> I'd suggest we open up this loop to copy more header values:
> /* Copy over other source metadata items as creation options */
> /* that seem useful. */
> char **papszSrcMD = poSrcDS->GetMetadata();
> int iMD;
> for( iMD = 0; papszSrcMD && papszSrcMD[iMD]; iMD++ )
> if( EQUALN(papszSrcMD[iMD],"NITF_BLOCKA",11)
> || EQUALN(papszSrcMD[iMD],"NITF_FHDR",9) )
> char *pszName = NULL;
> const char *pszValue = CPLParseNameValue( papszSrcMD[iMD],
> &pszName );
> if( CSLFetchNameValue( papszFullOptions, pszName+5 ) == NULL )
> papszFullOptions =
> CSLSetNameValue( papszFullOptions, pszName+5, pszValue
> ); CPLFree(pszName);
> Perhaps you could prepare a patch and test it and then submit it?
> Best regards,
> Frank
> On Fri, Apr 20, 2012 at 9:20 AM, Shawn Gong <SGONG at mdacorporation.com>
wrote:
> > Hi list,
> > I use gdal 1.9.0
> > I have a NITF image that has 12 bands. The first 8 are I and Q of a
> > quad-pol complex. I ran "gdal_translate -of NITF -b 9 -b 12 -b 10 -b 11
> > pp1.NTF test" to get rid of them and keep the last 4 magnitude bands.
> > However the NITF tags are altered, e.g. the NITF_ISORCE and NITF_IDATIM
> > Have you seen this?
> > I also see "Warning 1: FHDR=NITF02.1 not supported, switching to
> > NITF02.10." Can this be the cause?
> > Thanks,
> > Shawn
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> --- I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com light and sound - activate the windows |
> http://pobox.com/~warmerdam and watch the world go round - Rush |
> Geospatial Software
> Developer_______________________________________________ gdal-dev mailing
> list
