[gdal-dev] Topology Exceptions on Non-Noded Intersections
Even Rouault
even.rouault at mines-paris.org
Sat Aug 11 11:05:49 PDT 2012
Le mardi 07 août 2012 03:49:41, Sina Bahram a écrit :
> Eli,
> Sounds like the same problem to me, yes. thank you for finding that.
> However, now I'm still left wondering about implementing the fix.
> As I said in the StackExchange question, I think wrapdateline should fix
> this, but if not is there an easy way to split polygons along the
> dateline?
> Thanks for the response to this.
The TopologyException error comes from the GEOS library. You might need to
upgrade your GEOS to a newer version and see if it helps.
I've downloaded the
http://thematicmapping.org/downloads/TM_WORLD_BORDERS-0.3.zip dataset and
tried -wrapdateline on it. It works great. Except that it is not needed at all
since the longitudes of the dataset are between -180 and 180, so there's
nothing to wrap at all...
> Take care,
> Sina
> Website: www.SinaBahram.com
> Twitter: @SinaBahram
> -----Original Message-----
> From: Eli Adam [mailto:eadam at co.lincoln.or.us]
> Sent: Monday, August 06, 2012 9:19 PM
> To: Sina Bahram
> Subject: Re: [gdal-dev] Topology Exceptions on Non-Noded Intersections
> This is about Google Earth not Google Maps, but there may be something
> relevant here, http://blog.opengeo.org/2010/08/10/shape-of-a-polygon/
> Eli
> On Mon, Aug 6, 2012 at 5:50 PM, Sina Bahram <sbahram at nc.rr.com> wrote:
> > Hello,
> > I receive the following errors with the -wrapdateline argument.
> > ERROR 1: TopologyException: found non-noded intersection between
> > LINESTRING (-59.7742 -72.9003, -59.8494 -73.2331) and LINESTRING
> (0
> > -73.1221, -89.3211 -73.0542) at -59.8141 -73.0766
> > LINESTRING (-59.7742 -72.9003, -59.8494 -73.2331) and LINESTRING (180
> > -73.2589, -89.3211 -73.0542) at -59.8141 -73.0766
> > More details can be found on this question I asked:
> > http://gis.stackexchange.com/questions/30922/how-do-i-split-polygons-that
> > -cross-the-dateline
> > any advice?
> > Thanks
> > Take care,
> > Sina
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
