[gdal-dev] Topology Exceptions on Non-Noded Intersections
Sina Bahram sbahram at nc.rr.com
Sat Aug 11 12:33:06 PDT 2012
Then maybe I am explaining this problem wrong. If a polygon contains points that are close to -180 and 180 then things like MapKit
on IOS don't paint it correctly, instead taking the portion that crosses the line and stretching it around the world. In other
words, the shortest distance between something like -178 and 178 is not of length 4 but greater than 300 as it wraps around.
Is there a different solution that I can try to fix this problem?
Thank you for letting me know about GEOS possibly being out of date. I suppose I'll need to build that from source to get any newer,
as that's the latest in Ubuntu 12.04s repository.
Also, thank you for taking the time to download that dataset and try it out.
I've updated the StackExchange question with your findings:
http://gis.stackexchange.com/questions/30922/how-do-i-split-polygons-that-cross-the-dateline
any thoughts on how to fix this problem?
Take care,
Sina
Website: www.SinaBahram.com
Twitter: @SinaBahram
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Saturday, August 11, 2012 2:06 PM
To: gdal-dev at lists.osgeo.org
Cc: Sina Bahram
Subject: Re: [gdal-dev] Topology Exceptions on Non-Noded Intersections
Le mardi 07 août 2012 03:49:41, Sina Bahram a écrit :
> Eli,
> Sounds like the same problem to me, yes. thank you for finding that.
> However, now I'm still left wondering about implementing the fix.
> As I said in the StackExchange question, I think wrapdateline should fix
> this, but if not is there an easy way to split polygons along the
> dateline?
> Thanks for the response to this.
The TopologyException error comes from the GEOS library. You might need to
upgrade your GEOS to a newer version and see if it helps.
I've downloaded the
http://thematicmapping.org/downloads/TM_WORLD_BORDERS-0.3.zip dataset and
tried -wrapdateline on it. It works great. Except that it is not needed at all
since the longitudes of the dataset are between -180 and 180, so there's
nothing to wrap at all...
> Take care,
> Sina
> From: Eli Adam [mailto:eadam at co.lincoln.or.us]
> Sent: Monday, August 06, 2012 9:19 PM
> To: Sina Bahram
> This is about Google Earth not Google Maps, but there may be something
> relevant here, http://blog.opengeo.org/2010/08/10/shape-of-a-polygon/
> Eli
> On Mon, Aug 6, 2012 at 5:50 PM, Sina Bahram <sbahram at nc.rr.com> wrote:
> > Hello,
> > I receive the following errors with the -wrapdateline argument.
> > ERROR 1: TopologyException: found non-noded intersection between
> > LINESTRING (-59.7742 -72.9003, -59.8494 -73.2331) and LINESTRING
> (0
> > -73.1221, -89.3211 -73.0542) at -59.8141 -73.0766
> > LINESTRING (-59.7742 -72.9003, -59.8494 -73.2331) and LINESTRING (180
> > -73.2589, -89.3211 -73.0542) at -59.8141 -73.0766
> > More details can be found on this question I asked:
> > -cross-the-dateline
> > any advice?
> > Thanks
> > Take care,
> > Sina
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
