[gdal-dev] Compiling libCurl with GDAL v1.9
Paul Meems bontepaarden at gmail.com
Mon Aug 13 05:46:47 PDT 2012
Thanks all for your help.
@Jeff: I've tried that approach last year (with GDAL v1.8) and it gave me
nothing but trouble.
That is the reason I wanted to use precompiled curl libraries this time.
@Jukka, Tamas: I've successfully downloaded the zip files from
http://gisinternals.com/sdk/ and extracted the necessary files for Curl.
I didn't know that was possible.
This gave me the possibility to compile GDAL with our own settings AND use
the precompiled curl libraries.
As said I can compile now. I will now test if it is really working ;)
Perhaps the web page http://trac.osgeo.org/gdal/wiki/LibCurl should be
updated?
Thanks,
Paul
 *Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2012/8/13 Tamas Szekeres <szekerest at gmail.com>
> I recently used this option (curl 7.27.0), but a client reported
> performance problems with this approach. May be I would have been trying to
> disable one or more services which are compiled by default causing this
> side effect, but I rather went back to the original cmake approach
> instead. I've never experienced issues like this by using the cmake builds.
> Best regards,
> Tamas
> 2012/8/13 Jeff McKenna <jmckenna at gatewaygeomatics.com>
>> Hi Paul,
>> I compile libCurl with the MSVC compiler, and I follow the "MSVC from
>> command line" instructions at http://curl.haxx.se/docs/install.html
>> I set the ZLIB and OPENSSL paths as suggested as well.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> On 12-08-13 8:12 AM, Paul Meems wrote:
>> > Hi all,
>> > I'm trying (again) to compile GDAL with libCurl support.
>> > I'm on Windows using VS2008Pro.
>> > I'm using GDALv1.9.
>> > I went to this page http://trac.osgeo.org/gdal/wiki/LibCurl
>> > On this page a link is provided to a package.
>> > That link is no longer working.
>> > So I tried looking for the package myself.
>> > I've downloaded curl-7.27.0-ssl-sspi-zlib-static-bin-w32.zip from
>> > fossies.org <http://fossies.org> and curl-7.27.0-devel-mingw32.zip from
>> > haxx.se <http://haxx.se> both both don't have the needed lib files.
>> > So my question is:
>> > How to obtain the correct libCurl package?
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120813/ea7edeac/attachment.html>
