[gdal-dev] Compiling libCurl with GDAL v1.9
Tamas Szekeres szekerest at gmail.com
Mon Aug 13 05:38:21 PDT 2012
I recently used this option (curl 7.27.0), but a client reported
performance problems with this approach. May be I would have been trying to
disable one or more services which are compiled by default causing this
side effect, but I rather went back to the original cmake approach
instead. I've never experienced issues like this by using the cmake builds.
Best regards,
Tamas
2012/8/13 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hi Paul,
> I compile libCurl with the MSVC compiler, and I follow the "MSVC from
> command line" instructions at http://curl.haxx.se/docs/install.html
> I set the ZLIB and OPENSSL paths as suggested as well.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 12-08-13 8:12 AM, Paul Meems wrote:
> > Hi all,
> > I'm trying (again) to compile GDAL with libCurl support.
> > I'm on Windows using VS2008Pro.
> > I'm using GDALv1.9.
> > I went to this page http://trac.osgeo.org/gdal/wiki/LibCurl
> > On this page a link is provided to a package.
> > That link is no longer working.
> > So I tried looking for the package myself.
> > I've downloaded curl-7.27.0-ssl-sspi-zlib-static-bin-w32.zip from
> > fossies.org <http://fossies.org> and curl-7.27.0-devel-mingw32.zip from
> > haxx.se <http://haxx.se> both both don't have the needed lib files.
> > So my question is:
> > How to obtain the correct libCurl package?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120813/cc426d73/attachment.html>
