[gdal-dev] Access SVN revision number from runtime?
Even Rouault even.rouault at mines-paris.org
Thu Aug 16 01:15:15 PDT 2012
Selon Roger Bivand <Roger.bivand at nhh.no>:
> gcore/gdal_version.h gives us the hard-wired compile-time version string.
> GDALVersionInfo("--version") gives us the version known by the runtime. We
> can
> use GDALCheckVersion() to check that the two match (in rgdal/R). But is the
> SVN
> revision number exposed in the same way?
No, the revision number is not exposed in any way.
> A rgdal user on OpenSUSE has
> reported
> problems writing GTiff which turned out to stem from updates to the shared
> object having moved things leading to "Failure during IO":
> http://ssrebelious.blogspot.no/2012/08/rgdal-crash-solved.html. I think that
> the
> packagers may have been rolling their updates forward,
Not sure what happened there. Sounds like some weird packaging/installation
problem against which you cannot do much.
> so I'd like to provide
> a
> more fine-grained GDALCheckVersion() which also accesses the SVN revision. Is
> this possible (or sensible)?
I would advise against that. I'd go further : you should not even call
GDALCheckVersion() if RGDAL is only using the C API, which (in the GDAL 1.x
series) is forward compatible. I read your comment on the above blog that you
would refuse at runtime to run against GDAL 1.9.1 if RGDAL was compiled against
GDAL 1.9.0, but I don't think you want that. You want people to be able to
install bugfixes release of GDAL without requiring a rebuild of all packages
depending on GDAL. GDALCheckVersion() is mainly usefull for authors of plugins
to detect situations where they have compiled their plugin against GDAL 1.x and
at runtime are linking against GDAL 1.y, which for plugins using the C++ API
will not potentially work due to C++ ABI changes.
> Thanks,
> Roger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
