[gdal-dev] Access SVN revision number from runtime?
Roger Bivand
Roger.Bivand at nhh.no
Thu Aug 16 02:28:38 PDT 2012
On Thu, 16 Aug 2012, Even Rouault wrote:
> Selon Roger Bivand <Roger.bivand at nhh.no>:
>> gcore/gdal_version.h gives us the hard-wired compile-time version string.
>> GDALVersionInfo("--version") gives us the version known by the runtime. We
>> can
>> use GDALCheckVersion() to check that the two match (in rgdal/R). But is the
>> SVN
>> revision number exposed in the same way?
> No, the revision number is not exposed in any way.
>> A rgdal user on OpenSUSE has reported problems writing GTiff which
>> turned out to stem from updates to the shared object having moved
>> things leading to "Failure during IO":
>> http://ssrebelious.blogspot.no/2012/08/rgdal-crash-solved.html. I think
>> that the packagers may have been rolling their updates forward,
> Not sure what happened there. Sounds like some weird packaging/installation
> problem against which you cannot do much.
Right, this was my basic feeling, but given the tone of his blog, I
thought I'd ask. Thanks gor responding so fast!
>> so I'd like to provide a more fine-grained GDALCheckVersion() which
>> also accesses the SVN revision. Is this possible (or sensible)?
> I would advise against that. I'd go further : you should not even call
> GDALCheckVersion() if RGDAL is only using the C API, which (in the GDAL
> 1.x series) is forward compatible. I read your comment on the above blog
> that you would refuse at runtime to run against GDAL 1.9.1 if RGDAL was
> compiled against GDAL 1.9.0, but I don't think you want that. You want
> people to be able to install bugfixes release of GDAL without requiring
> a rebuild of all packages depending on GDAL. GDALCheckVersion() is
> mainly usefull for authors of plugins to detect situations where they
> have compiled their plugin against GDAL 1.x and at runtime are linking
> against GDAL 1.y, which for plugins using the C++ API will not
> potentially work due to C++ ABI changes.
The rgdal source is part C (for proj), part C++ for OGR/GDAL, but C++
written by C-minded people, so no new classes, but using C++ OGR/GDAL
classes, things like: pDataset->~GDALDataset();. As I understand you,
1.x.a and 1.x.b share the C++ ABI, but say 1.x.b and 1.y.a will probably
not.
This suggests that I may use GDALCheckVersion(GDAL_VERSION_MAJOR,
GDAL_VERSION_MINOR, NULL); to get something that might help users debug
performance failures, but that GDAL_VERSION_REV is too fine-grained.
Best wishes,
Roger
>> Thanks,
>> Roger
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
