[gdal-dev] reprojecting SRTM data
Zoltan Szecsei zoltans at geograph.co.za
Thu Aug 16 03:39:59 PDT 2012
On 2012/08/16 11:43, Vincent Schut wrote:
> On 08/16/12 11:14, Zoltan Szecsei wrote:
>> But the software I want to use this tif-DEM in complains:
>> Error encountered while reading GeoTIFF file:  Elevation data must
>> be specified as 32-bit floating point samples.
> Hi Zoltan,
> you can add "-ot Float32" to your gdalwarp command to produce a 32-bit
> floating point file (which your software seems to want).
> Best,
> Vincent.
Muahahaha - works like a dream - Thanks!
You know, one of the unsaid benefits of open source, is that the
programmer actually is also a user.
THAT is why we have all these practical and useful  little parameters. :-)
Well done to the developer of this one.
Regards,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897  Mobile: +27-83-6004028
Fax: +27-86-6115323     www.geograph.co.za
