[gdal-dev] write JPEG2000 with codek KAKADU without .tif
Evgeniy Borovenskiy eborovenskiy at scanex.ru
Thu Aug 16 04:09:56 PDT 2012
The thing is when I try to save the buffer with an image that is being saved in the operative memory when my program is working and when the KAKADU's driver tries to create JPEG2000 for the file recording the driver isn't created. It's because there's no function 'Create' in JP2KAKDataset. But there's the function 'JP2KAKCreateCopy' in which the recording of JPEG2000 format happens from the file with the format .tif. The driver GTiffDataset is created when it's impossible to create the driver for KAKADU. The question is this: is it possible to make a record JPEG2000 directly? Is it possible to create the driver KAKADU directly, to write the function 'Create' for KAKADU and why has it happened before?
Evgeniy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120816/af5c312b/attachment.html>
