[gdal-dev] How use the esri-filegdb
Andrea Peri aperi2007 at gmail.com
Sun Aug 26 02:51:26 PDT 2012
I like to test the esri-filegdb with ogr2ogr.
So I'm reading information from gdal and from esri.
Reading the gdal information on file-gdb format,
http://www.gdal.org/ogr/drv_filegdb.html
I read:
>Bulk feature loading (OGR >= 2.0)
>Special SQL requests (OGR >= 2.0)
this mean I should use the trunk version of gdal to test this options ?
Or, instead, this is an ption actually not available ?
Also I see theat in the instruction is write:
>Dataset Creation Options
>none
This mean that the driver is not capable to create a new empty database ?
Thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120826/842e0184/attachment.html>
