[gdal-dev] How use the esri-filegdb
Even Rouault
even.rouault at mines-paris.org
Sun Aug 26 03:24:39 PDT 2012
Le dimanche 26 août 2012 11:51:26, Andrea Peri a écrit :
> Hi,
> I like to test the esri-filegdb with ogr2ogr.
> So I'm reading information from gdal and from esri.
> Reading the gdal information on file-gdb format,
> http://www.gdal.org/ogr/drv_filegdb.html
> I read:
> >Bulk feature loading (OGR >= 2.0)
> >Special SQL requests (OGR >= 2.0)
> this mean I should use the trunk version of gdal to test this options ?
Yes, when this is documented as GDAL/OGR >= 2.0, it means it is available with
trunk (we don't advertize features that are not implemented at all)
> Also I see theat in the instruction is write:
> >Dataset Creation Options
> >none
> This mean that the driver is not capable to create a new empty database ?
No, this means that there's no special option to specify. Dataset creation
options are the ones that may be passed with the -dsco flag of ogr2ogr.
> Thx,
