[gdal-dev] Building gdal 1.9.1 on AIX with
chen zhen
zhenchen17 at gmail.com
Thu Aug 30 23:37:06 PDT 2012
Frank,
Thanks.
Another problem.
I got the similar situation with this post :
http://trac.osgeo.org/gdal/ticket/2375.
It is caused by minor difference definition in inttypes.h between Linux(
CentOS 6.3 at hand) and AIX (6.1). int32 data type is defined intypes.h on
AIX but not on Linux. There is a conflict in shpopen.c by defining int32 by
hand. There is no good way tell the platform strictly unless adding
preprocessor -DAIX or something like:
#ifndef _H_INTTYPES /* inttypes.h macro on AIX compared to _INTTYPES_H on
Linux */
#endif
Any comments?
Regards,
zhen
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
> Sent: Friday, August 31, 2012 2:18 PM
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Building gdal 1.9.1 on AIX with
> On 12-08-30 10:01 PM, chen zhen wrote:
> > Hi All,
> > I met a compile problem when trying to build gdal 1.9.1 on AIX
> > platform with xlc toolset. Here is the compile log:
> > make[2]: Entering directory
> `/home/sdb/BeyonDB_20/ads_3rlib/gdal/frmts/ers'
> > /bin/sh /home/sdb/BeyonDB_20/ads_3rlib/gdal/libtool --mode=compile
> > --tag=CXX xlc_r -q32 -q32 -Wall
> > -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/port
> > -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/gcore
> > -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/alg
> > -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/ogr
> > -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/ogr/ogrsf_frmts -I../raw
> > -DOGR_ENABLED -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/port
> > -I/home/sdb/BeyonDB_20/ads_3rlib/jpeg/temp
> > -I/home/sdb/BeyonDB_20/ads_3rlib/jpeg/temp/include
> > -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp
> > -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp/include -c -o
> > ../o/ersdataset.lo ersdataset.cpp
> > libtool: compile: xlc_r -q32 -q32 -Wall
> > -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp/include -c ersdataset.cpp
> > -o ../o/ersdataset.o
> > xlc_r: 1501-289 (W) Option -Wall was incorrectly specified. The option
> > will be ignored.
> > "ersdataset.cpp", line 690.41: 1540-0207 (S) No common type found for
> > operands with type "CPLString" and "const char [4]".
> > "ersdataset.cpp", line 691.42: 1540-0207 (S) No common type found for
> > operands with type "CPLString" and "const char [6]".
> > "ersdataset.cpp", line 692.42: 1540-0207 (S) No common type found for
> > operands with type "CPLString" and "const char [7]".
> > "ersdataset.cpp", line 1048.51: 1540-0207 (S) No common type found for
> > "ersdataset.cpp", line 1049.52: 1540-0207 (S) No common type found for
> > "ersdataset.cpp", line 1050.52: 1540-0207 (S) No common type found for
> > make[2]: *** [../o/ersdataset.lo] Error 1
> > make[2]: Leaving directory
> > the correspond source code in ersdataset.cpp is :
> > oSRS.importFromERM( osProj.size() ? osProj : "RAW",
> > osDatum.size() ? osDatum : "WGS84",
> > osUnits.size() ? osUnits : "METERS" );
> > It seems the compiler can't convert a CPLString to a const char []
> > format. However there is a cast operator in CPLString declaration:
> > operator const char* (void) const { return c_str(); }
> > I am not sure why the xlc compiler can't recognize this cast
> > operation, maybe it think const char [] and const char * are
> > different?
> > I modified the source code a bit which does an explicit cast, it at
> > least passed the compiling.
> > oSRS.importFromERM( osProj.size() ? (const char *)osProj : "RAW",
> > osDatum.size() ? (const char *)osDatum :
> "WGS84",
> > osUnits.size() ? (const char *)osUnits :
> > "METERS" );
> > I am looking for if there is any way working around this issue(such
> > as adding a compile parameter to xlc) or should this be a patch that
> > mkes gdal playing will on AIX?
> Zhen,
> I don't know why this confuses xlc but the work around is harmless enough
so
> please feel free to submit a patch via trac once the build completes
> successfully.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://home.gdal.org/warmerda
> and watch the world go round - Rush | Geospatial Software Developer
> gdal-dev mailing list
