[gdal-dev] GDAL 1.9.2 still looking for GEOS 3.3.5 after geos upgrade
Eduardo Kanegae
eduardo.kanegae at gmail.com
Tue Dec 4 04:56:51 PST 2012
hi,
After upgrading from geos 3.3.5 to 3.3.6, I'm trying to upgrade from
GDAL 1.9.1 to 1.9.2.
Compiling process is done, but when trying to run any gdal* executable
I got the error:
gdalinfo: error while loading shared libraries: libgeos-3.3.5.so:
cannot open shared object file: No such file or directory
At /usr/local/lib I got:
-rwxr-xr-x. 1 root /root 18M Dez 3 08:36 /usr/local/lib/libgeos-3.3.6.so
-rw-r--r--. 1 root /root 48M Dez 3 08:36 /usr/local/lib/libgeos.a
-rw-r--r--. 1 root /root 1,9M Dez 3 08:36 /usr/local/lib/libgeos_c.a
-rwxr-xr-x. 1 root /root 979 Dez 3 08:36 /usr/local/lib/libgeos_c.la
lrwxrwxrwx. 1 root /root 18 Dez 3 08:36 /usr/local/lib/libgeos_c.so
-> libgeos_c.so.1.7.6
/usr/local/lib/libgeos_c.so.1 -> libgeos_c.so.1.7.6
-rwxr-xr-x. 1 root /root 907K Dez 3 08:36 /usr/local/lib/libgeos_c.so.1.7.6
-rwxr-xr-x. 1 root /root 947 Dez 3 08:36 /usr/local/lib/libgeos.la
lrwxrwxrwx. 1 root /root 16 Dez 3 08:36 /usr/local/lib/libgeos.so
-> libgeos-3.3.6.so
Is there any special hint I'm missing here?
Eduardo Patto Kanegae
http://www.webmapit.com | @webmapit
