[gdal-dev] gdalwarp performance with many GCPs
Knut-Frode Dagestad knutfrodesoppel at hotmail.com
Wed Dec 12 04:12:49 PST 2012
Hi list,
When warping images with many GCPs, the -tps switch (Thin Plate Spline)
is found to be necessary to get decent accuracy. This makes however
warping very slow. The only method I found to increase speed is the -et
switch, but at cost of spatial accuracy.
Below some comments about the other tries which did not help:
- compiling GDAL with armadillo support had no effect on speed.
Btw, to compile with armadillo I had to manually insert -llapack in the
following line in configure:
if test -z "`${CXX} testarmadillo.cpp -o testarmadillo -larmadillo
2>&1`" ; then .....
Perhaps ${LIBS} should be added permanently to this line in trunk?
- compiling GDAL with OpenCL had also no effect. At first surprising,
but looking at the opencl warp kernel it seems that it only makes a
difference for other resampling algorithms than nearest neighbour?
- Increasing  memory with -wm had no effect
- Using several threads (-multi -wo NUM_THREADS=ALL_CPUS) actually
increased computing time significantly (my proj version is 4.7.1).
 From the debug output, a lot of the time is apparently spent on:
"WARP: Copying metadata from first source to destination dataset"
Is this an indication that much time is simply spent on reading and
writing the GCPs to/from file? If so, we could perhaps expect improved
performance if Geolocation Arrays could be used instead (not possible
due to http://trac.osgeo.org/gdal/ticket/4907).
The tests are made with the following file and command on Ubuntu:
http://dl.dropbox.com/u/15885758/testgcp.tif  (3212 GCPs and 2048x2511
pixels covering Southern Europe)
time gdalwarp --debug on -et 5 -tps -t_srs '+proj=merc' testgcp.tif
out.tif  (+ other swithces mentioned above)
Best regards from Knut-Frode
