[gdal-dev] image Compilation of Qgis 1.8 with gdal svn (Windows7_64bits)
lcelati at latitude-geosystems.com
Wed Dec 19 16:55:44 PST 2012
Hello,
3*Thank you for your reply. I just edit the nmake.opt in adding these
following sentences :
!IFNDEF VERSION
VERSION = 19
!ENDIF
I place its at the end of section called "########### END OF STUFF THAT
NORMALLY NEEDS TO BE UPDATED ################## "
Can you tell me if I put these sentences in the right place in the file?
I send you the new nmake.opt.
4* Indeed, i succeed in compiling gdal svn version thanks to tortoise svn &
visual studio. For information , i send you the web link of this gdal svn
version already compiled : https://svn.osgeo.org/gdal/
So I will compile again this version of gdal svn as soon as a little some
time.
Thank to throw light for me.
With kind regards.
IMAGE.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Compilation-of-Qgis-1-8-with-gdal-svn-Windows7-64bits-tp5022355p5023996.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
