[gdal-dev] Problem re-projecting shapefile by using ogr2ogr
deb
otrov at hush.ai
Wed Dec 12 16:21:27 PST 2012
I want to re-project shapefile from current projection (whatever that is) to ESPG:4326.
My example layer (misc.shp) is in EPSG:31227:
> ogrinfo -al -so misc.shp
INFO: Open of `misc.shp'
using driver `ESRI Shapefile' successful.
Layer name: misc
Geometry: Line String
Feature Count: 10
Extent: (21.267388, 42.015857) - (21.270225, 42.017470)
Layer SRS WKT:
PROJCS["MGI_Balkans_zone_7_deprecated",
GEOGCS["GCS_MGI",
DATUM["Militar_Geographische_Institute",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",21],
PARAMETER["scale_factor",0.9999],
PARAMETER["false_easting",7500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
As suggested by couple of sources from Google search results, I used this:
> ogr2ogr -t_srs EPSG:4326 misc_re.shp misc.shp
And then investigate metadata of newly creates vector:
> ogrinfo -al -so misc_re.shp
INFO: Open of `misc_re.shp'
Layer name: misc_re
Feature Count: 10
Extent: (-34.004490, 0.000230) - (-34.004490, 0.000230)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_84",6378137,298.257223563]],
There is no projection (PROJCS) in metadata and coordinates are different from source vector.
I then tried various EPSG codes, and I get PROJCS metadata, but Extent values are totally different for each projection, so even if I assume some units issue, there can't be that different units in existence.
Can anyone give me a pointer where I did wrong?
Thanks
