[gdal-dev] GCP reprojection
Fabian Schindler
fabian.schindler at eox.at
Tue Dec 18 07:06:53 PST 2012
Hey devs,
I've spent a full day to find a solution to this, but unfortunately was
not able to solve it, so you are my last hope :)
I'm trying to reproject an image with GCPs to a CRS specified by WKT.
I used `gdal.AutoCreateWarpedVRT` to retrieve the output image size +
geotransform in conjunction with `gdal.ReprojectImage` to reproject the
image. This worked well unless I have really few GCPs at my disposal
(i.e: 6), then I just get the error "Failed to compute GCP transform:
Transform is not solvable". (Funnily it works with only 4 GCPs).
I created a small C function to get the size and geotransform from an
image with few GCPs (basically a small, Python callable wrapper for
GDALSuggestedWarpOutput) with `order = 1` which helped me around the
`gdal.AutoCreateWarpedVRT` error. But now I'm stuck with the
`gdal.ReprojectImage`, which gives me the exact same error as above.
("Failed to compute GCP transform: Transform is not solvable"). I've
also tried to create a wrapper here to use `order=1` but this time it
did not help and the error stayed.
My raster image size is 605x595 and I want to apply the following GCPs:
pixel line lon lat
0.000000 0.000000 -> 16.100000 48.500000
604.000000 0.000000 -> 16.168000 48.503300
604.000000 297.000000 -> 16.168035 48.483500
604.000000 594.000000 -> 16.168040 48.463600
0.000000 594.000000 -> 16.100100 48.460000
0.000000 297.000000 -> 16.100000 48.480000
Is there any (C) function I can use instead? Or any other method to
reproject images with few GCPs?
Thanks,
Fabian
P.S: I'm using GDAL 1.9.1 on CentOS 6.
