[gdal-dev] GCP reprojection
Fabian Schindler fabian.schindler at eox.at
Tue Dec 18 07:12:17 PST 2012
Sorry for the traffic, just forgot to say that with the command line
utilities it works as expected:
gdal_translate -gcp 0 0 16.1 48.5 -gcp 604 0 16.168 48.5033 -gcp 604 297
16.168035 48.4835 -gcp 604 594 16.16804 48.4636 -gcp 0 594 16.1001 48.46
-gcp 0 297 16.1 48.48 input.jpg tmp.tif
gdalwarp -order 1 tmp.tif output.tif
Thanks,
Fabian
On 12/18/2012 04:06 PM, Fabian Schindler wrote:
> Hey devs,
> I've spent a full day to find a solution to this, but unfortunately
> was not able to solve it, so you are my last hope :)
> I'm trying to reproject an image with GCPs to a CRS specified by WKT.
> I used  `gdal.AutoCreateWarpedVRT` to retrieve the output image size +
> geotransform in conjunction with `gdal.ReprojectImage` to reproject
> the image. This worked well unless I have really few GCPs at my
> disposal (i.e: 6), then I just get the error "Failed to compute GCP
> transform: Transform is not solvable". (Funnily it works with only 4
> GCPs).
> I created a small C function to get the size and geotransform from an
> image with few GCPs (basically a small, Python callable wrapper for
> GDALSuggestedWarpOutput) with `order = 1` which helped me around the
> `gdal.AutoCreateWarpedVRT` error. But now I'm stuck with the
> `gdal.ReprojectImage`, which gives me the exact same error as above.
> ("Failed to compute GCP transform: Transform is not solvable"). I've
> also tried to create a wrapper here to use `order=1` but this time it
> did not help and the error stayed.
> My raster image size is 605x595 and I want to apply the following GCPs:
> pixel      line          lon       lat
> 0.000000   0.000000   -> 16.100000 48.500000
> 604.000000 0.000000   -> 16.168000 48.503300
> 604.000000 297.000000 -> 16.168035 48.483500
> 604.000000 594.000000 -> 16.168040 48.463600
> 0.000000   594.000000 -> 16.100100 48.460000
> 0.000000   297.000000 -> 16.100000 48.480000
> Is there any (C) function I can use instead? Or any other method to
> reproject images with few GCPs?
> Thanks,
> Fabian
> P.S: I'm using GDAL 1.9.1 on CentOS 6.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
