[gdal-dev] HDF4 support for gdal 1.8
    Tamas Szekeres
    szekerest at gmail.com
    Wed Feb  1 13:17:33 EST 2012
If you have a compiled version of the HDF4 libraries, you could probably
use the SDK from gisinternals <http://www.gisinternals.com/sdk/> to include
that in the build (Makefile should be edited). I have never tried it by
myself, but I'll give it a try as my time permits.
Best regards,
Tamas
2012/2/1 singnage <singh01 at gmail.com>
> I recently installed GDAL 1.8.1 from gisinternals.com/sdk on Windows 7, I
> was
> previously using 1.6 from FW Tools, this newer version does not support
> HDF4 but supports HDF5, can anyone point how can I install the HDF4 support
> for version 1.8.1.
> thanks
> NS
> http://osgeo-org.1560.n6.nabble.com/HDF4-support-for-gdal-1-8-tp4356589p4356589.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120201/4adedd32/attachment.html
