[gdal-dev] Re: Getting SRID from ESRI shapefile
Hermann Peifer peifer at gmx.eu
Mon Feb 6 11:29:41 EST 2012
On 06/02/2012 14:52, Etienne Tourigny wrote:
> I have been working on experimental EPSG lookup, see ticket #4345
> http://trac.osgeo.org/gdal/ticket/4345
> It requires gdalsrsinfo from gdal-1.9 and some extra data files
> installed in the gdal data directory (see the ticket)
It could perhaps be an idea to make it more clear in the ticket which
extra data files are needed (as there is quite a list of attachments).
I also tried to run gen_epsg_wkt.sh and ended up with a lot of:
ERROR 1: ERROR - wkt_old output not supported
I guess this should read: wkt_simple
Hermann
