[gdal-dev] Re: Getting SRID from ESRI shapefile
Etienne Tourigny etourigny.dev at gmail.com
Mon Feb 6 12:56:16 EST 2012
The ticket is sort of a mess as there are 2 experimental features in there...
I have updated the ticket with more information and a modified shell script.
Etienne
On Mon, Feb 6, 2012 at 2:29 PM, Hermann Peifer <peifer at gmx.eu> wrote:
> On 06/02/2012 14:52, Etienne Tourigny wrote:
>> I have been working on experimental EPSG lookup, see ticket #4345
>> http://trac.osgeo.org/gdal/ticket/4345
>> It requires gdalsrsinfo from gdal-1.9 and some extra data files
>> installed in the gdal data directory (see the ticket)
> It could perhaps be an idea to make it more clear in the ticket which extra
> data files are needed (as there is quite a list of attachments).
> I also tried to run gen_epsg_wkt.sh and ended up with a lot of:
> ERROR 1: ERROR - wkt_old output not supported
> I guess this should read: wkt_simple
> Hermann
