[gdal-dev] Geolocation Arrays ??
Brian Case rush at winkey.org
Tue Feb 7 17:46:10 EST 2012
Etienne
with the transformer the way it sits now, in most cases you will need to
specify -te xmin ymin xmax ymax with gdalwarp to avoid that error
Brian
On Tue, 2012-02-07 at 19:22 -0200, Etienne Tourigny wrote:
> Even, Frank,
> thanks for your answers.  I have run into a problem with using
> gdalwarp with geoloc transform.
> In ticket #1895 there is an hdf file for which the HDF4 driver creates
> GEOLOCATION metadata.
> Trying gdalwarp on it gives an error, and the result transform is
> incorrect.  Am I doing something wrong, or is this a bug?
> command is : gdalwarp -geoloc -t_srs EPSG:4326
> HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13 tmp1.tif
> more info below:
> $ gdalinfo HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13
> Driver: HDF4Image/HDF4 Dataset
> Files: A2006005182000.L2_LAC_SST.x.hdf
> Size is 389, 602
> Coordinate System is `'
> Metadata:
> Geolocation:
>   LINE_OFFSET=0
>   LINE_STEP=1
>   PIXEL_OFFSET=0
>   PIXEL_STEP=1
>   SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
>   X_BAND=1
>   X_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":11
>   Y_BAND=1
>   Y_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":12
> Corner Coordinates:
> $ gdalwarp -geoloc -t_srs EPSG:4326
> Creating output file that is 31119P x 5864L.
> Processing input file HDF4_SDS:UNKNOWN:A2006005182000.L2_LAC_SST.x.hdf:13.
> ERROR 1: Too many points (441 out of 441) failed to transform,
> unable to compute output bounds.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> $ gdalinfo tmp1.tif
> Driver: GTiff/GeoTIFF
> Files: tmp1.tif
> Size is 31119, 5864
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
> Origin = (-90.198287963867188,90.300000000000011)
> Pixel Size = (0.015398926739995,-0.015398926739995)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  ( -90.1982880,  90.3000000) ( 90d11'53.84"W, 90d18' 0.00"N)
> Lower Left  ( -90.1982880,   0.0006936) ( 90d11'53.84"W,  0d 0' 2.50"N)
> Upper Right (     389.001,      90.300) (Invalid angle, 90d18' 0.00"N)
> Lower Right (     389.001,       0.001) (Invalid angle,  0d 0' 2.50"N)
> Center      ( 149.4013126,  45.1503468) (149d24' 4.73"E, 45d 9' 1.25"N)
> Regards,
> Etienne
> On Tue, Feb 7, 2012 at 7:05 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > On Tue, Feb 7, 2012 at 7:40 AM, Etienne Tourigny
> > <etourigny.dev at gmail.com> wrote:
> >> Hi all,
> >> I would like to have information on the status of geolocation array
> >> support in GDAL.
> >> The relevant RFC4 (http://trac.osgeo.org/gdal/wiki/rfc4_geolocate)  is
> >> still "under development", and the information there is that
> >> GDALCreateGeoLocTransformer "is currently partially implemented".
> > Etienne,
> > I think the geoloc transformer received some fixes from someone
> > other than myself and now is working reasonable well.  It would
> > be desirable to freshen up the RFC and get it passed but it isn't
> > particularly a priority of mine so I'm not likely to drive it in the
> > very near future.
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
