[gdal-dev] Geolocation Arrays ??
Etienne Tourigny
etourigny.dev at gmail.com
Tue Feb 7 16:22:47 EST 2012
Even, Frank,
thanks for your answers. I have run into a problem with using
gdalwarp with geoloc transform.
In ticket #1895 there is an hdf file for which the HDF4 driver creates
GEOLOCATION metadata.
Trying gdalwarp on it gives an error, and the result transform is
incorrect. Am I doing something wrong, or is this a bug?
command is : gdalwarp -geoloc -t_srs EPSG:4326
HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13 tmp1.tif
more info below:
$ gdalinfo HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13
Driver: HDF4Image/HDF4 Dataset
Files: A2006005182000.L2_LAC_SST.x.hdf
Size is 389, 602
Coordinate System is `'
Metadata:
Geolocation:
LINE_OFFSET=0
LINE_STEP=1
PIXEL_OFFSET=0
PIXEL_STEP=1
SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
X_BAND=1
X_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":11
Y_BAND=1
Y_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":12
Corner Coordinates:
$ gdalwarp -geoloc -t_srs EPSG:4326
Creating output file that is 31119P x 5864L.
Processing input file HDF4_SDS:UNKNOWN:A2006005182000.L2_LAC_SST.x.hdf:13.
ERROR 1: Too many points (441 out of 441) failed to transform,
unable to compute output bounds.
0...10...20...30...40...50...60...70...80...90...100 - done.
$ gdalinfo tmp1.tif
Driver: GTiff/GeoTIFF
Files: tmp1.tif
Size is 31119, 5864
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
Origin = (-90.198287963867188,90.300000000000011)
Pixel Size = (0.015398926739995,-0.015398926739995)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -90.1982880, 90.3000000) ( 90d11'53.84"W, 90d18' 0.00"N)
Lower Left ( -90.1982880, 0.0006936) ( 90d11'53.84"W, 0d 0' 2.50"N)
Upper Right ( 389.001, 90.300) (Invalid angle, 90d18' 0.00"N)
Lower Right ( 389.001, 0.001) (Invalid angle, 0d 0' 2.50"N)
Center ( 149.4013126, 45.1503468) (149d24' 4.73"E, 45d 9' 1.25"N)
Regards,
Etienne
On Tue, Feb 7, 2012 at 7:05 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On Tue, Feb 7, 2012 at 7:40 AM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Hi all,
>> I would like to have information on the status of geolocation array
>> support in GDAL.
>> The relevant RFC4 (http://trac.osgeo.org/gdal/wiki/rfc4_geolocate) is
>> still "under development", and the information there is that
>> GDALCreateGeoLocTransformer "is currently partially implemented".
> Etienne,
> I think the geoloc transformer received some fixes from someone
> other than myself and now is working reasonable well. It would
> be desirable to freshen up the RFC and get it passed but it isn't
> particularly a priority of mine so I'm not likely to drive it in the
> very near future.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
