[gdal-dev] PostGIS SRID conundrum
Sandro Santilli strk at keybit.net
Tue Feb 14 05:05:18 EST 2012
On Sat, Feb 11, 2012 at 6:48 AM, Martin Chapman <chapmanm at pixia.com> wrote:
> 4.       I select the max(srid) where srid > 10000000.  If zero is
> returned then I  use that base number (10000000) and add a new entry to the
> spatial_ref_sys table using the proj4 text and wkt so all fields have a
> value…and my app name as the authority (makes me feel important J).  If a
> max above 10000000 is found then I take the max and add one and then add
> the new entry.Guys, the MAXIMUM
The MAXIMUM valid user value for SRID in PostGIS-2.0 is 998999 so please
consider using values in the range 910000..910999 for your custom entries.
--strk;
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120214/c004e93f/attachment.html
