[gdal-dev] PostGIS SRID conundrum
Martin Chapman
chapmanm at pixia.com
Tue Feb 14 12:35:18 EST 2012
Sandro,
Thank you very much for the info!
Best regards,
Martin
From: sandro.santilli at gmail.com [mailto:sandro.santilli at gmail.com] On Behalf
Of Sandro Santilli
Sent: Tuesday, February 14, 2012 3:05 AM
To: Martin Chapman
Cc: pcreso at pcreso.com; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] PostGIS SRID conundrum
On Sat, Feb 11, 2012 at 6:48 AM, Martin Chapman <chapmanm at pixia.com> wrote:
4. I select the max(srid) where srid > 10000000. If zero is returned
then I use that base number (10000000) and add a new entry to the
spatial_ref_sys table using the proj4 text and wkt so all fields have a
value…and my app name as the authority (makes me feel important J). If a
max above 10000000 is found then I take the max and add one and then add the
new entry.Guys, the MAXIMUM
The MAXIMUM valid user value for SRID in PostGIS-2.0 is 998999 so please
consider using values in the range 910000..910999 for your custom entries.
--strk;
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120214/f7293f81/attachment.html
