[gdal-dev] compiling gdal on Ubuntu via Parallels
Stuart Edwards sedwards2 at cinci.rr.com
Wed Feb 22 11:33:13 EST 2012
On Feb 22, 2012, at 10:16 AM, Even Rouault wrote:
> Selon Stuart Edwards <sedwards2 at cinci.rr.com>:
>> Hi
>> This seems to be an old problem  (see
>> http://www.osgeo.org/pipermail/gdal-dev/2009-October/022308.html) but when I
>> try to compile GDAL 1.9.0 from source using Ubuntu 10.04 through Parallels
>> Desktop 6.0.12106 on OS X 10.6.8 (don't ask why this convoluted approach -
>> long ESRI related story)  I get the following message during 'make':
>> ar:   /usr/local/gdal/frmts/o/aaigriddataset.o:   No such file or directory.
>> and indeed,
>> ls  /usr/local/gdal/frmts/o
>> produces a listing for aaigriddataset.lo , but unlike the other files in the
>> directory, no corresponding aaigriddataset.o
> Perhaps try ./configure --without-libtool . But no promise this will help
seemed to compile without problem, but then gdalinfo gives ' gedalinfo: error while loading shared libraries: libgdal.so: cannot open shared object file: No such file or directory'
thx for the help
Stu
