[gdal-dev] compiling gdal on Ubuntu via Parallels
Kyle Shannon KShannon at gcs-research.com
Wed Feb 22 11:41:08 EST 2012
On newer Ubuntu releases /usr/local/lib is not in the LD_LIBRARY_PATH.  Either set it in your login script (export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH or add /usr/local/lib to /etc/ld.so.conf
If you do the latter method, run sudo ldconfig after you are done and it should work.
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Stuart Edwards
Sent: Wednesday, February 22, 2012 9:33 AM
To: Even Rouault
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] compiling gdal on Ubuntu via Parallels
On Feb 22, 2012, at 10:16 AM, Even Rouault wrote:
> Selon Stuart Edwards <sedwards2 at cinci.rr.com>:
>> Hi
>> This seems to be an old problem  (see
>> http://www.osgeo.org/pipermail/gdal-dev/2009-October/022308.html) but
>> when I try to compile GDAL 1.9.0 from source using Ubuntu 10.04
>> through Parallels Desktop 6.0.12106 on OS X 10.6.8 (don't ask why
>> this convoluted approach - long ESRI related story)  I get the following message during 'make':
>> ar:   /usr/local/gdal/frmts/o/aaigriddataset.o:   No such file or directory.
>> and indeed,
>> ls  /usr/local/gdal/frmts/o
>> produces a listing for aaigriddataset.lo , but unlike the other files
>> in the directory, no corresponding aaigriddataset.o
> Perhaps try ./configure --without-libtool . But no promise this will
> help
seemed to compile without problem, but then gdalinfo gives ' gedalinfo: error while loading shared libraries: libgdal.so: cannot open shared object file: No such file or directory'
thx for the help
Stu
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
