[gdal-dev] compiling gdal on Ubuntu via Parallels
Stuart Edwards
sedwards2 at cinci.rr.com
Wed Feb 22 12:55:40 EST 2012
that seems to have taken care of the problem - thanks!
Stu
On Feb 22, 2012, at 11:41 AM, Kyle Shannon wrote:
> On newer Ubuntu releases /usr/local/lib is not in the LD_LIBRARY_PATH. Either set it in your login script (export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH or add /usr/local/lib to /etc/ld.so.conf
> If you do the latter method, run sudo ldconfig after you are done and it should work.
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Stuart Edwards
> Sent: Wednesday, February 22, 2012 9:33 AM
> To: Even Rouault
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] compiling gdal on Ubuntu via Parallels
> On Feb 22, 2012, at 10:16 AM, Even Rouault wrote:
>> Selon Stuart Edwards <sedwards2 at cinci.rr.com>:
>>> Hi
>>> This seems to be an old problem (see
>>> http://www.osgeo.org/pipermail/gdal-dev/2009-October/022308.html) but
>>> when I try to compile GDAL 1.9.0 from source using Ubuntu 10.04
>>> through Parallels Desktop 6.0.12106 on OS X 10.6.8 (don't ask why
>>> this convoluted approach - long ESRI related story) I get the following message during 'make':
>>> ar: /usr/local/gdal/frmts/o/aaigriddataset.o: No such file or directory.
>>> and indeed,
>>> ls /usr/local/gdal/frmts/o
>>> produces a listing for aaigriddataset.lo , but unlike the other files
>>> in the directory, no corresponding aaigriddataset.o
>> Perhaps try ./configure --without-libtool . But no promise this will
>> help
> seemed to compile without problem, but then gdalinfo gives ' gedalinfo: error while loading shared libraries: libgdal.so: cannot open shared object file: No such file or directory'
> thx for the help
> Stu
> gdal-dev mailing list
