[gdal-dev] Strange behaviour of gdal_translate with ECW on
linux (libecw 3.3)
andreaerdna
andreaerdna at libero.it
Mon Feb 27 14:26:32 EST 2012
Sylvain Maffren wrote
> I try to convert RGB tiff file (300 Mo) into ECW ( libecw 3.3 and gdal
> 1.8.1 that I have compiled) using this gdal_translate command, on a
> Debian Squeeze : gdal_translate -of "ECW" -co LARGE_OK="YES" -co
> TARGET="90" -co DATUM="RGF93" -co PROJ="LMFRAN93" file_in.tif
> file_out.ecw, and I get strange results.
Hi Sylvain,
I also am doing some tests about ECW encoding with GDAL using different OS
(Windows XP 32 bit / Windows 7 64 bit / Linux Ubuntu 10.04 64 bit),
different GDAL versions and ECW plugin (1.9.0 / 1.8.1 / 1.8.0 / 1.7.3 /
1.7.0b2) from different origins (www.gisinternals.com / OSGeo4W / FWTools /
ubuntugis launchpad repository / ERDAS sources), and with or without a
TARGET creation option set.
I'll post the results as soon as the tests are completed.
Andrea Giudiceandrea
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-Strange-behaviour-of-gdal-translate-with-ECW-on-linux-libecw-3-3-tp4498738p4516105.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
