[gdal-dev] Re: GDAL Java Binding meomory problem under intensive
method calls
easyl
thlin.box at gmail.com
Fri Jan 6 05:53:51 EST 2012
your are right!
It fixed the problem!!
Actually I have another question (after fixing the violation bug).
Can I implement ogrtindex in Java as well?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-Java-Binding-meomory-problem-under-intensive-method-calls-tp7155011p7157990.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
