[gdal-dev] Re: GDAL Java Binding meomory problem under intensive method calls
Even Rouault even.rouault at mines-paris.org
Fri Jan 6 07:27:40 EST 2012
> Can I implement ogrtindex in Java as well?
I've scanned quickly ogrtindex.cpp and I believe that all the APIs it uses are
exposed in the Java bindings, so yes it looks like it is doable. I see that
there's a large part of the code that does various checks. You can probably skip
some of them if you are sure not to go into those conditions in your use cases.
