[gdal-dev] VRT Plugin
Yves Jacolin
yjacolin at free.fr
Mon Jan 9 11:50:02 EST 2012
Hello,
I get this error with one of my function of my vrt plugins:
Band 1 Block=128x128 Type=Float32, ColorInterp=Undefined
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: IReadBlock failed at X offset 1, Y offset 0
ERROR 1: IReadBlock failed at X offset 0, Y offset 1
ERROR 1: IReadBlock failed at X offset 1, Y offset 1
ERROR 1: IReadBlock failed at X offset 0, Y offset 2
ERROR 1: IReadBlock failed at X offset 1, Y offset 2
ERROR 1: Failed to compute min/max, no valid pixels found in sampling.
This function is:
CPLErr waveDirToUFunc(void **papoSources, int nSources, void *pData,
int nXSize, int nYSize,
GDALDataType eSrcType, GDALDataType eBufType,
int nPixelSpace, int nLineSpace)
int iLine, iCol, ii;
double pix_val;
double x0;
/* ---- Init ---- */
if (nSources < 2) return CE_Failure;
/* ---- Set pixels ---- */
if (GDALDataTypeIsComplex( eSrcType ))
/*double adfPixVal[2], dfOldR, dfOldI, dfNewR, dfNewI;*/
/*void *pReal, *pImag;*/
/*int nOffset = GDALGetDataTypeSize( eSrcType ) / 8 / 2;*/
for( iLine = 0, ii= 0; iLine < nYSize; ++iLine ) {
for( iCol = 0; iCol < nXSize; ++iCol, ++ii ) {
x0 = SRCVAL(papoSources[0], eSrcType, ii);
pix_val = cos(x0*0.1*PI/180);
GDALCopyWords(&pix_val, GDT_Float64, 0,
((GByte *)pData) + nLineSpace * iLine + iCol *
nPixelSpace,
eBufType, nPixelSpace, 1);
/* ---- Return success ---- */
return CE_None;
} /* waveDirToUFunc */
Data range value is 0 to 3600.
Any idea? Thanks,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
