[gdal-dev] End User Questions :( KML Raster to Shapefile
Brian Case
rush at winkey.org
Tue Jan 17 14:07:58 EST 2012
Dennis
gdal does not have any code for reading raster files in kml/kmz like
that. can you make the files you have available so i can look?
Brian
On Mon, 2012-01-16 at 17:11 -0600, Dennis Burgess wrote:
> I have a .KML File and .PNG file or a .TIF along with a .GEO file that
> my application exports.
> Once there, I need to convert these to a shape file for mailing lists,
> but so far I have only found several application extensions that do
> this, but nothing command line. I believe that the gdaltindex could
> work, but it shoots me back a no georeferencing is avail for the
> getotif.tif files ..
> Any suggestions would be great.
> Dennis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
