[gdal-dev] easiest way to merge commits from trunk to a branch?
Etienne Tourigny etourigny.dev at gmail.com
Mon Jan 23 21:25:26 EST 2012
Hi devs,
what is the preferred way to apply a fix to a branch, given a specific
commit to trunk?
I have tried from within the branch root directory  the command 'svn
merge  -c 23794 ../../../trunk/gdal/ .', which works but generates a
few non-related diffs like:
Property changes on: apps/gdaldem.cpp
___________________________________________________________________
Modified: svn:mergeinfo
   Merged /trunk/gdal/apps/gdaldem.cpp:r23794
Is there a way to get rid of these diffs permanently, or is there
another command I should use? I would prefer not to have to save and
then apply diffs each time.
regards,
Etienne
