[gdal-dev] ElasticSearch Driver
Adam Estrada estrada.adam at gmail.com
Tue Jan 24 15:27:03 EST 2012
All,
I have been using ElasticSearch as a way to perform some advanced analysis
on feature attribute data. From my work with ElasticSearch came the
ogr2elasticsearch GDAL driver. The code can be found here.
http://code.google.com/p/ogr2elasticsearch/
Every time I rebuild GDAL I have to add this driver back to the build path
so that I can take advantage of it which is unfavorable. What would it take
to get this driver included in to trunk GDAL?
Thanks in advance,
Adam
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120124/8d5da1d5/attachment.html
