[gdal-dev] ElasticSearch Driver
Tue Jan 24 15:49:21 EST 2012
On Tue, Jan 24, 2012 at 12:27 PM, Adam Estrada <estrada.adam at gmail.com> wrote:
> All,
> I have been using ElasticSearch as a way to perform some advanced analysis
> on feature attribute data. From my work with ElasticSearch came the
> ogr2elasticsearch GDAL driver. The code can be found
> here. http://code.google.com/p/ogr2elasticsearch/
> Every time I rebuild GDAL I have to add this driver back to the build path
> so that I can take advantage of it which is unfavorable. What would it take
> to get this driver included in to trunk GDAL?
Adam,
My suggestion is that you file a ticket with a patch or even just a zip
of the relavent code.  I notice your driver uses the jsonc library.  It
would be helpful to ensure this code is not duplicated between the
elastic search and geojson driver.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
