[gdal-dev] Creating DXF with ogr2ogr
Carman, Darren darren.carman at infoterra-global.com
Thu Jan 26 10:00:01 EST 2012
Try adding -nlt POLYGON (also has POINT and LINESTRING options).
We have this option on an older version that used the ODA libraries
directly, so can't guarantee it's still the same.
Darren
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Verena Diewald
Sent: 26 January 2012 14:03
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Creating DXF with ogr2ogr
Hi all,
I'm trying to create DXF files from a PostgreSQL database using ogr2ogr:
ogr2ogr -nln my_data -a_srs EPSG:25832 -s_srs EPSG:25832 -t_srs
EPSG:25832 -f "DXF" my_data.dxf PG:'host=localhost password=xxx user=xxx
dbname=MYDB' -sql "SELECT * FROM my_data"
It works fine with point data, but I get an invalid dxf file for polygon
data. Opening the polygon dxf file results in the following error:
The following error was encountered while reading
in HATCH starting at line 1546:
Error: expected group code 10
Invalid or incomplete DXF input -- drawing discarded.
Do I have to pass any more options to ogr2ogr when creating a polygon
dxf? What did I do wrong?
Does anyone have an idea about that?
Greetings,
Verena
Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist.
Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement.
Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27.
P Before printing, think about the environment
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/b1cc5690/attachment.html
