[gdal-dev] Creating DXF with ogr2ogr
Verena Diewald verena.diewald at wheregroup.com
Thu Jan 26 10:56:48 EST 2012
Hi Darren,
I tried that option, but the error still remains.
Does anyone have another idea?
Greetings,
Verena
Am 26.01.2012 16:00, schrieb Carman, Darren:
> Try adding -nlt POLYGON (also has POINT and LINESTRING options).
> We have this option on an older version that used the ODA libraries
> directly, so can't guarantee it's still the same.
> Darren
> *From:*gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Verena Diewald
> *Sent:* 26 January 2012 14:03
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* [gdal-dev] Creating DXF with ogr2ogr
> Hi all,
> I'm trying to create DXF files from a PostgreSQL database using ogr2ogr:
> |ogr2ogr -nln my_data -a_srs EPSG:25832 -s_srs EPSG:25832 -t_srs EPSG:25832 -f "DXF" my_data.dxf PG:'host=localhost password=xxx user=xxx dbname=MYDB' -sql "SELECT * FROM my_data"|
> It works fine with point data, but I get an invalid dxf file for
> polygon data. Opening the polygon dxf file results in the following error:
> The following error was encountered while reading
> in HATCH starting at line 1546:
> Error: expected group code 10
> Invalid or incomplete DXF input -- drawing discarded.
> Do I have to pass any more options to ogr2ogr when creating a polygon
> dxf? What did I do wrong?
> Does anyone have an idea about that?
> Greetings,
> Verena
> Infoterra Ltd. Is part of the Astrium GEO-Information Services
> Division and a wholly owned subsidiary of Astrium, Europe's leading
> space systems and services specialist.
> Disclaimer. The information contained in this e-mail and its
> attachments are confidential and intended only for the use of the
> named addressee(s). If you are not the intended addressee, please do
> not read, copy, use or disclose this message or its attachments. If
> you have received this message in error, please notify the sender
> immediately and delete or destroy all copies of this message and
> attachments in all media. Any views or opinions expressed are solely
> those of the author and do not necessarily represent those of
> Infoterra Ltd and shall not form part of any binding agreement.
> Infoterra Limited a company registered in England under number 2359955
> and having its registered office at Atlas House, 41 Wembley Road,
> Leicester, LE3 1UT. VAT number GB 476 0468 27.
> P Before printing, think about the environment
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/02236185/attachment-0001.html
