[gdal-dev] Creating DXF with ogr2ogr
Ralf Suhr
Ralf.Suhr at itc-halle.de
Thu Jan 26 11:20:29 EST 2012
Hi Verena,
can you provide more information. What software version did you use (gdal,
postgis). What kind of geometries is in the database.
psql -d mydb -c "SELECT DISTINCT GeometryType( geom_column ) FROM my_data"
What happend if you select only one geometrytype from database.
ogr2ogr -f "DXF" -sql "SELECT * FROM my_data WHERE GeometryType( geom_column )
= 'POLYGON'" my_data.dxf PG:'host=localhost password=xxx user=xxx dbname=MYDB'
Gr
Ralf
On Donnerstag 26 Januar 2012 16:56:48 Verena Diewald wrote:
> Hi Darren,
> I tried that option, but the error still remains.
> Does anyone have another idea?
> Greetings,
> Verena
> Am 26.01.2012 16:00, schrieb Carman, Darren:
> > Try adding -nlt POLYGON (also has POINT and LINESTRING options).
> > We have this option on an older version that used the ODA libraries
> > directly, so can't guarantee it's still the same.
> > Darren
> > *From:*gdal-dev-bounces at lists.osgeo.org
> > [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Verena Diewald
> > *Sent:* 26 January 2012 14:03
> > *To:* gdal-dev at lists.osgeo.org
> > *Subject:* [gdal-dev] Creating DXF with ogr2ogr
> > Hi all,
> > I'm trying to create DXF files from a PostgreSQL database using ogr2ogr:
> > |ogr2ogr -nln my_data -a_srs EPSG:25832 -s_srs EPSG:25832 -t_srs
> > |EPSG:25832 -f "DXF" my_data.dxf PG:'host=localhost password=xxx
> > |user=xxx dbname=MYDB' -sql "SELECT * FROM my_data"|
> > It works fine with point data, but I get an invalid dxf file for
> > polygon data. Opening the polygon dxf file results in the following
> > error:
> > The following error was encountered while reading
> > in HATCH starting at line 1546:
> > Error: expected group code 10
> > Invalid or incomplete DXF input -- drawing discarded.
> > Do I have to pass any more options to ogr2ogr when creating a polygon
> > dxf? What did I do wrong?
> > Does anyone have an idea about that?
> > Greetings,
> > Verena
> > Infoterra Ltd. Is part of the Astrium GEO-Information Services
> > Division and a wholly owned subsidiary of Astrium, Europe's leading
> > space systems and services specialist.
> > Disclaimer. The information contained in this e-mail and its
> > attachments are confidential and intended only for the use of the
> > named addressee(s). If you are not the intended addressee, please do
> > not read, copy, use or disclose this message or its attachments. If
> > you have received this message in error, please notify the sender
> > immediately and delete or destroy all copies of this message and
> > attachments in all media. Any views or opinions expressed are solely
> > those of the author and do not necessarily represent those of
> > Infoterra Ltd and shall not form part of any binding agreement.
> > Infoterra Limited a company registered in England under number 2359955
> > and having its registered office at Atlas House, 41 Wembley Road,
> > Leicester, LE3 1UT. VAT number GB 476 0468 27.
> > P Before printing, think about the environment
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/75baaf78/attachment.html
