[gdal-dev] Re-loading non-spatial data using OGR2OGR
J. Burnson
jburnson at yahoo.com
Thu Jan 26 13:59:29 EST 2012
Did you mean CPL_DEBUG ON? Here is the output:
OCI: Prepare(CREATE TABLE "R_SIGN_OGR" ( OGR_FID INTEGER))
ERROR 1: ORA-00955: name is already used by an existing object in CREATE TABLE "R_SIGN_OGR" ( OGR_FID INTEGER)
ERROR 1: Terminating translation prematurely after failed translation of layer R_Sign (use -skipfailures to skip errors)
For reference, here is the table that ogr2ogr created on the first pass:
SQL> desc r_sign_ogr
Name Null? Type
OGR_FID NUMBER(38)
field_1 VARCHAR2(2047 CHAR)
field_2 VARCHAR2(2047 CHAR)
Adding MULTI_LOAD=NO had no discernible effect.
John
--- On Thu, 1/26/12, Chaitanya kumar CH <chaitanya.ch at gmail.com> wrote:
From: Chaitanya kumar CH <chaitanya.ch at gmail.com>
Subject: Re: [gdal-dev] Re-loading non-spatial data using OGR2OGR
To: "J. Burnson" <jburnson at yahoo.com>
Cc: gdal-dev at lists.osgeo.org
Date: Thursday, January 26, 2012, 12:10 PM
John,
Try setting the layer creation option MULTI_LOAD to NO using -lco with ogr2ogr and the configuration option CPL_DEBUG to OFF [1]. I hope to get at least a more usable error message.
[1]: http://trac.osgeo.org/gdal/wiki/ConfigOptions
On Thu, Jan 26, 2012 at 10:31 PM, J. Burnson <jburnson at yahoo.com> wrote:
I am trying to load a non-spatial CSV file into Oracle using ogr2ogr (GDAL 1.8.1). It works on the first attempt (when no destination table exists) but in later attempts, I get "name is already used by an existing object".
ogr2ogr -append -f OCI OCI:user/password at db -nln r_sign_ogr X:/R_Sign.csv -nlt NONE
I have tried every combination of overwrite/append/update that I can think of, as well as using "-nlt NONE". I do not have trouble re-populating spatial tables.
Any suggestions would be welcome! Thank you,
John
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/15404e4f/attachment.html
