[gdal-dev] Re-loading non-spatial data using OGR2OGR
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jan 26 13:10:24 EST 2012
John,
Try setting the layer creation option MULTI_LOAD to NO using -lco with
ogr2ogr and the configuration option CPL_DEBUG to OFF [1]. I hope to get
at least a more usable error message.
[1]: http://trac.osgeo.org/gdal/wiki/ConfigOptions
On Thu, Jan 26, 2012 at 10:31 PM, J. Burnson <jburnson at yahoo.com> wrote:
> Hi,
> I am trying to load a non-spatial CSV file into Oracle using ogr2ogr (GDAL
> 1.8.1). It works on the first attempt (when no destination table exists)
> but in later attempts, I get "name is already used by an existing object".
> ogr2ogr -append -f OCI OCI:user/password at db -nln r_sign_ogr X:/R_Sign.csv
> -nlt NONE
> I have tried every combination of overwrite/append/update that I can think
> of, as well as using "-nlt NONE". I do not have trouble re-populating
> spatial tables.
> Any suggestions would be welcome! Thank you,
> John
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/f647da13/attachment.html
