[gdal-dev] gdalwarp makes landcover files blocky when shrinking
pixel size
Dmitry Baryshnikov
polimax at mail.ru
Fri Jan 27 01:49:19 EST 2012
27.01.2012 3:39, John Twilley пишет:
> I am working with elevation and landcover data downloaded from the
> USGS. I use gdalwarp to convert the data to a much smaller pixel. The
> elevation data works very nicely with cubic resampling, but the only
> resampling that works at all for the landcover data is
> nearest-neighbor and that's very blocky. When I last worked with
> landcover data, I used a majority algorithm which produced smoother
> output -- but that algorithm is not implemented in gdalwarp.
> I am looking over the source to gdalwarp to see how hard it is to add
> a new algorithm. Other than that, though, what options are available
> to me? Thanks in advance!
> Jack.--
> mathuin at gmail dot com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hi John,
That is your command line string for gdalwarp?
Best regards,
Dmitry
