[gdal-dev] gdalwarp makes landcover files blocky when shrinking
pixel size
John Twilley
mathuin at gmail.com
Fri Jan 27 11:19:33 EST 2012
After retrieving the files and building VRTs from them, I run the
following gdalwarp commands:
gdalwarp -q -multi -t_srs "+proj=aea +datum=NAD83 +lat_1=29.5
+lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0 +y_0=0 +units=m" -tr 6 6 -te
2002944 2271744 2016768 2288640 \
-srcnodata -340282346638528859811704183484516925440 -dstnodata 0
ND302HT.vrt ND302HT.tif
-srcnodata 255 -dstnodata 11 L0102HT.vrt L0102HT.tif
The only differences between the lines are the nodata values.
Jack.
mathuin at gmail dot com
On Thu, Jan 26, 2012 at 22:49, Dmitry Baryshnikov <polimax at mail.ru> wrote:
> 27.01.2012 3:39, John Twilley пишет:
>> I am working with elevation and landcover data downloaded from the
>> USGS. I use gdalwarp to convert the data to a much smaller pixel. The
>> elevation data works very nicely with cubic resampling, but the only
>> resampling that works at all for the landcover data is
>> nearest-neighbor and that's very blocky. When I last worked with
>> landcover data, I used a majority algorithm which produced smoother
>> output -- but that algorithm is not implemented in gdalwarp.
>> I am looking over the source to gdalwarp to see how hard it is to add
>> a new algorithm. Other than that, though, what options are available
>> to me? Thanks in advance!
>> Jack.--
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Hi John,
> That is your command line string for gdalwarp?
> Best regards,
> Dmitry
