[gdal-dev] plate caree and EPSG:4326
Alfredo Alessandrini
alfreale74 at gmail.com
Mon Jan 30 08:28:19 EST 2012
I'm trying to reproject the VGT-P product with the gdal libraries.
The metafile is reported below.
It's right to assume the EPSG 4326 code as source spatial reference set?
Thanks,
Alfredo
MAP_PROJ_NAME PLATE_CARREE_1KMG nom provisoirement egal au code
MAP_PROJ_FAMILY UNPROJECTED
MAP_PROJ_CODE PLATE_CARREE_1KMG
MAP_PROJ_UNIT DEGREES
MAP_PROJ_RESOLUTION 0.0089285714
GEODETIC_SYST_NAME WGS 1984
GEODETIC_SYST_CODE WG84
HORIZ_DATUM WGS 1984
MERIDIAN_NAME GREENWICH
MERIDIAN_ORIGIN +000.000
SPHEROID_NAME WGS 1984
SPHEROID_SEMI_MAJ_AXIS 6378137.000
SPHEROID_SEMI_MIN_AXIS 6356752.314
CARTO_UPPER_LEFT_X 91.267857
CARTO_UPPER_LEFT_Y 72.232143
CARTO_UPPER_RIGHT_X 154.160714
CARTO_UPPER_RIGHT_Y 72.232143
CARTO_LOWER_RIGHT_X 154.160714
CARTO_LOWER_RIGHT_Y -8.241071
CARTO_LOWER_LEFT_X 91.267857
CARTO_LOWER_LEFT_Y -8.241071
View this message in context: http://osgeo-org.1560.n6.nabble.com/plate-caree-and-EPSG-4326-tp4350647p4350647.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
