[gdal-dev] plate caree and EPSG:4326
Jose Gomez-Dans jgomezdans at gmail.com
Mon Jan 30 09:05:54 EST 2012
Hi
On 30 January 2012 13:28, Alfredo Alessandrini <alfreale74 at gmail.com> wrote:
> Hi,
> I'm trying to reproject the VGT-P product with the gdal libraries.
> It's right to assume the EPSG 4326 code as source spatial reference set?
I don't think they are the same. Plate Carree is an equidistance
cylindrical projection. I used a different EPSG (32662) for this same data
with success, although it shows are "deprecated"...:
http://spatialreference.org/ref/epsg/32662/
Hope that helps
Jose
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120130/bae36aa5/attachment.html
