[gdal-dev] gdal_merge.py on large Tiff's. gdalwarp not working properly.
aphunter a1hunter at ucsd.edu
Sat Jul 7 23:38:58 PDT 2012
Thanks for the suggestion. Unfortunately building the .vrt file as you
suggested, and using gdal_translate, gives me the same fractured image that
gdal_warp does. I am not sure why gdal_merge.py works properly while the
others don't.
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-merge-py-on-large-Tiff-s-gdalwarp-not-working-properly-tp4986729p4986741.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
