[gdal-dev] gdal_merge.py on large Tiff's. gdalwarp not working properly.
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Jul 7 20:45:08 PDT 2012
Aaron,
You can use a combination of gdalbuildvrt and gdal_translate.
gdalbuildvrt both.vrt one_26911.tif two_26911.tif
gdal_translate both.vrt both.tif
On Sun, Jul 8, 2012 at 5:44 AM, aphunter <a1hunter at ucsd.edu> wrote:
> Hi community!
> Here's my issue. I currently have two halves of California, one in
> EPSG:26910, and one in EPSG:26911. I successfully reprojected the 26910
> segment into zone 26911, and if I make the images small, to test,
> gdal_merge.py works properly. See below:
> http://osgeo-org.1560.n6.nabble.com/file/n4986729/screenshot.92.png
> Unfortunately, the original images are too large to use gdal_merge.py,
> because I don't have enough memory on my system. They are each about 1.5T
> in
> size.
> When I use gdalwarp to combine the images, I get a horrible space in the
> middle. See below.
> http://osgeo-org.1560.n6.nabble.com/file/n4986729/screenshot.93.png
> Can anybody help me either use gdalwarp properly to combine the two Tiff's,
> or get gdal_merge.py to work with Tiff's larger than the amount of memory I
> have on my system?
> Any help is greatly appreciated!
> Thanks in advance,
> Aaron
> http://osgeo-org.1560.n6.nabble.com/gdal-merge-py-on-large-Tiff-s-gdalwarp-not-working-properly-tp4986729.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120708/644fbc2b/attachment.html>
