[gdal-dev] Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
taibc
taibc_coltech at yahoo.com
Fri Jul 13 02:55:08 PDT 2012
Although, I added 'gdal_i.lib' in Properties (Linker ->Input->Additional Dependencies) and this file in Debug folder, but I got an other errror:
error LNK1104: cannot open file 'gdal_i.lib'
Do you know how to fix it ?
Thanks and regards,
Tai
gdal-dev mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/gdal-dev
You mast remove any cpl_*.cpp and any gdal headers from your
solution. In project properties you have to put path to gdal headers
(gdal_root/port, gdal_root/gcore, gdal_root/ogr)
E.g. for GDALVersionInfo function you have to include only in your
code #include "gdal.h"
Best regards,
Dmitry
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988142.html
To unsubscribe from Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010, click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988177.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120713/4103bf00/attachment.html>
