[gdal-dev] Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
Dmitry Baryshnikov polimax at mail.ru
Fri Jul 13 03:02:21 PDT 2012
13.07.2012 13:55, taibc ?????:
> Hi,
> Although, I added 'gdal_i.lib' in Properties (Linker
> ->Input->Additional Dependencies) and this file in Debug folder, but I
> got an other errror:
> error LNK1104: cannot open file 'gdal_i.lib'
> Do you know how to fix it ?
> Thanks and regards,
> Tai
>> gdal-dev mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Hi,
> You mast remove any cpl_*.cpp and any gdal headers from your solution.
> In project properties you have to put path to gdal headers
> (gdal_root/port, gdal_root/gcore, gdal_root/ogr)
> E.g. for GDALVersionInfo function you have to include only in your
> code #include "gdal.h"
> Best regards,
>     Dmitry
> [hidden email]
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988142.html
> To unsubscribe from Error LNK1120: 314 unresolved externals - When
> using Ogr C++ class on Visual Studio 2010, click here.
> NAML
> <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Error LNK1120: 314 unresolved
> <http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988177.html>
> Sent from the GDAL - Dev mailing list archive
> <http://osgeo-org.1560.n6.nabble.com/GDAL-Dev-f3742093.html> at
> Nabble.com.
> gdal-dev at lists.osgeo.org
Put there (Linker ->Input->Additional Dependencies) the full path to
gdal_i.lib or add the path to gdal_i.lib in Linker
->General->AdditionalLibraryDirectories
Best regards,
     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120713/3417b2ae/attachment-0001.html>
