[gdal-dev] Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
taibc taibc_coltech at yahoo.com
Fri Jul 13 03:18:27 PDT 2012
Hi Dmitry,
After modifying as you said, I got many errors like below:
error LNK2019: unresolved external symbol _CSLPartialFindString referenced in function "public: int __thiscall CPLStringList::PartialFindString(char const *)const " (?PartialFindString at CPLStringList@@QBEHPBD at Z)
Thanks and regards,
Tai
 From: Dmitry Baryshnikov [via OSGeo.org] <ml-node+s1560n4988180h99 at n6.nabble.com>
To: taibc <taibc_coltech at yahoo.com>
Sent: Friday, July 13, 2012 5:03 PM
Subject: Re: Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
13.07.2012 13:55, taibc пишет:
>Although, I added 'gdal_i.lib' in Properties (Linker
        ->Input->Additional Dependencies) and this file in Debug
        folder, but I got an other errror:
>error LNK1104: cannot open file 'gdal_i.lib'
>Do you know how to fix it ?
>Thanks and regards,
>Tai
>_______________________________________________
gdal-dev mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/gdal-dev
>You mast remove any cpl_*.cpp and any gdal headers from
              your solution. In project properties you have to put path
              to gdal headers (gdal_root/port, gdal_root/gcore,
              gdal_root/ogr)
>E.g. for GDALVersionInfo function you have to include only
              in your code #include "gdal.h"
>Best regards,
>    Dmitry
>[hidden email]
>If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988142.html
>To unsubscribe from Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010, click here.
>NAML
> View this message in context: Re: Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
>Sent from the GDAL - Dev mailing list archive at Nabble.com.
Put there (Linker ->Input->Additional Dependencies) the full path to gdal_i.lib or add the path to gdal_i.lib in Linker ->General->AdditionalLibraryDirectories
Best regards,
    Dmitry
[hidden email]
http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988180.html
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988184.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120713/4b67bf17/attachment.html>
